Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer)
these files in the main input deck.
Import Files Import various file types into the selected client.
Warning Messages When Loading Files
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load Files
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save Files
Save all of the data in your current session.
Export Files Export various file types from the selected client to another format.
Include Files
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
