Create New Files
Create a new file.
Do one of the following:
The current file is cleared from the memory, and the new file opens.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
Create a new file.
ON THIS PAGE
Create a new file.
ON THIS PAGE
