Open Files
Open a file.
- If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
- Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
- If the directory is not valid, the file dialog opens in the application start-in directory.
Do one of the following:
- From the Home tools, Files tool group, click the Open Model tool.
Figure 1. - From the menu bar, select .
- Press Ctrl + O.
- In the Open File dialog, navigate to your working directory and select the file to open.
- If needed, define any options in the Open Options dialog then click Open.
HyperWorks loads model files and solver input files with the solver interface they were saved in.
- To open recently used files, select menu bar.
Click
to pin a file to the list.
from the - Quickly open an .hm file by dragging-and-dropping it from a file browser into the modeling window.
For more information on opening model files in HyperView, see Opening Animation Files.
For more information on opening time history files in HyperGraph, see Create Curves by File.
