Create Beam Structural Elements
Beam structural elements can be meshed with 1D elements or shell elements.
From the Certification ribbon, click the Beam
tool.
Figure 1. -
When Structural elements are created, a structural property can be selected.
Click
to define how properties are assigned.
Each structural element must have a structural property assigned to it in order to run method.- Single property
- Assigns the same structuralproperty entity to all designpoints.
- Duplicate and assign property to all
- Creates a new instance of selected structuralproperty and assign the copy to all designpoints.
- Duplicate and assign property per designpoint
- Creates a new instance of selected structuralproperty per designpoint entity.
- This option performs a deep copy, meaning the structural property's references, such as materiel/property or beamsection, are also copied. Each structural property generated is fully independent.
- This is useful for design exploration where you will update structural properties separately.
Mesh with 1D or shell elements.
Option Description 1D Mesh In this case, as shown in Figure 2, the result will be a Member, extracted as a collection of 1D elements representing a true Beam between intersection points.
- Set the entity type on the first selector to Elements.
- Optionally, select a destination DesignPointSet to hold
newly created designpoints.
If no set is selected, a new one will be created with config Beam and type Beam_member.
If you enter this menu from the Certification Browser context menu using Auto DDP, then the selector will be pre-populated with the selected designpointset.
- Specify a structuralproperty entity (of config beam) if the
Absorb FE Property checkbox is
unselected.
Otherwise, a structural property is absorbed from the model by collecting the beamsection/material pair assigned to the bar2/rod element closest to the center of each designpoint.
Figure 2. Extract MembersShell Mesh In the event of a shell mesh which represents structural beams, you need to first generate freebody sections using a dedicated tool. As shown in Figure 3, the result will be a designpoint entity per freebody section
- Set the entity type on the first selector to Freebody Sections.
If no set is selected, a new one will be created with config Beam and type Beam_shell.
- Specify a structuralproperty entity (of config beam), the
same as for 1D beams.
The Absorb FE Property checkbox does not exist for this use case.
Figure 3. Beams from freebody sections -
On the guide bar, click one of the following:
- Save changes and stay in the tool
- Save changes and close the tool
