HDF5 Export
Use the HDF5 Export tool to generate a Nastran HDF5 file across the solver.
You can export full or portions of HyperMesh model data and HyperMesh post results data in a neutral Nastran (MSC) HDF5 format. The HyperMesh model and results can be exported in a solver neutral format so that you can develop an external application based on a single neutral data source without worrying about solver formats.
