/SHVER/V51 (Obsolete)
Engine Keyword The new large rotational body motion formulation for QEPH, QBAT and DKT18 will be deactivated.
View new features for Radioss 2021.1.
Radioss format 2021 uses the 12x extension format.
Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
Engine Keyword Subcycling on Lagrangian parts.
Engine Keyword Defines a section cut on a deformed geometry.
Engine Keyword Defines a section cut on the initial geometry.
Engine Keyword Defines a section cut on a deformed geometry using three nodes.
Engine Keyword In animation files, keep deleted elements in their original part; otherwise group all deleted elements in an extra part (named "deleted elements").
Engine Keyword Quasi-incompressible formulation for fluid material (compatible with /MAT/LAW6 and /MAT/LAW11).
Engine Keyword Enables you to modify coefficients for standard upwind formulation previously defined from Starter Input or from previous run.
Engine Keyword This describes the Streamline Upwind Petrov Galerkin formulation.
Engine Keyword Describes the Taylor Galerkin method for momentum advection. This method is not available with multi-material LAW51 (/MAT/MULTIMAT).
Engine Keyword With ALE links on grid velocities, given nodes are linked to the given main grid velocities. You can specify direction or a combination of directions.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
This manual describes the interface between Altair Radioss and a user’s subroutines.
