/ANIM/CUT/2 (Obsolete)
Engine Keyword Defines a section cut on the initial geometry.
/ANIM/CUT/2
Name
x0, y0, and z0 nx, ny, and nz V
Name | Name of the section cut | |
x0, y0, and z0 | Coordinates of a reference point | |
nx, ny, and nz | Normal vector | |
V | Velocity |
- The deformed plane cut is defined in the initial geometry by the coordinates of a reference point (x0, y0, and z0 ) and a normal vector (nx, ny, and nz). The plane cut moves along the normal vector with velocity V.
- When using the mass option /ANIM/MASS, the balance displayed in the post-processing is the volumetric flux.
- This keyword is not available for SPMD version.
