/SHSUB
Engine Keyword Enables you to activate new sub-cycling option, for which Isubcycle =2 in the /ANALY Radioss Starter option should be specified.
/SHSUB/NSH print/NSH ctrl
NSH print | Defines the output frequency (in the output file or .out file in new extension) for the shell elements, over sub-cycles (that is to say over the only cycles for which internal forces of shell elements are computed). | |
NSH ctrl | In some cases where the
sub-cycling time step falls down, shells may need to be computed
each cycle and this process may require to be more CPU
time-consuming than deactivating sub-cycling. Default = 1000 |
- It is possible to make a run with sub-cycling and to switch after restart to a non sub-cycling (standard) computation, and reciprocally.
- NSH print defines the output frequency
(in the output file .out in new extension) for the shell
elements, over subcycles (that is to say over the only cycles for which internal
With a negative value, the printing is also done to the standard output.
This additional output to the .out file for Radioss Engine will be written with frequency NSH_print over subcycles:
in case of /DT/SHNOD (nodal time step for SHELL and SH3N elements sub-cycling):NC T DTSUB NODE SUBCYCLE
Where,- NC
- Current cycle number
- T
- Current time
- DTSUB
- Time step for sub-cycling
- NODE
- SUBCYCLE
- node_ID
- Sub-cycle number
At this time, the node_ID gives the time step for sub-cycling.
else:NC T DTSUB SHELL or SH3N SUBCYCLE
Where,- NC
- T
- Current time
- DTSUB
- SHELL or SH3N
- shell_ID or sh3n_ID
- SUBCYCLE
- Sub-cycle number
At this time, the shell_ID or sh3n_ID gives the time step for sub-cycling.
- NSH ctrl has been introduced with the
/SHSUB keyword, since in case of the sub-cycling time
step falls down, shells may need to be computed each cycle and this process may
become some more CPU time consuming than deactivating sub-cycling.
Indeed, shells and 3-nodes shell elements are computed each time step, corresponding to the stability time step for shells: sub-cycling time step is a stability time step related to shells.
NSH ctrl: if NSH ctrl cycles are computed without sub-cycling, that is to say if shell elements are computed each cycle during NSH ctrl consecutive cycles, the sub-cycling method will be deactivated by Radioss Engine.
- Shells and 3-nodes shell elements are computed each time step, corresponding to the stability time step for shells: sub-cycling time step is a stability time step related to shells.
- In case of element time step
(/DT/NODA is not specified in the Radioss Engine Input deck):Where,
- Characteristic length
- c
- Sound speed of the related material
Parameters of /DT/SHELL will be considered, especially for the value of (default value is 0.9). Parameters of the sub-options /DT/SHELL will be normally considered.
- In
case of nodal time step (/DT/NODA is specified in the Radioss Engine Input deck).Where,
- m
- Nodal mass
- Ksh
- Stiffness corresponding to the connected shells
- The value given in /DT/NODA; but may be changed by using /DT/SHNOD
