/RAD2RAD/ON
Engine Keyword To activate Multi-Domain coupling, Radioss Engine Input file must contain the following directive.
/RAD2RAD/ON
View new features for Radioss 2021.1.
Radioss format 2021 uses the 12x extension format.
Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword The Engine is stopped and restart files are not created, if one of the following criteria is exceeded.
Engine Keyword Activates MADYMO- Radioss coupling.
Engine Keyword Provides an estimation of the CPU time spent for each processor.
Engine Keyword Solid element control for elements with negative volumes. Switch to small strain formulation or stop the run a solid elements volume becomes negative.
Engine Keyword Turns the parallel arithmetic ON/OFF.
Engine Keyword Permits to continue a previous Radioss run.
Engine Keyword Identifies the run number.
Engine Keyword Enables you to activate new sub-cycling option, for which Isubcycle =2 in the /ANALY Radioss Starter option should be specified.
Engine Keyword The Engine is stopped, due to reached energy error ratio criteria, total mass ratio criteria or nodal mass ratio criteria.
Engine Keyword The Engine is stopped due to sensor activation, when the first sensor in the defined list is activated.
Engine Keyword Thermal analysis.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
This manual describes the interface between Altair Radioss and a user’s subroutines.
/RAD2RAD/ON
