/RERUN
Engine Keyword Permits to continue a previous Radioss run.
/RERUN/Run Name/Run Number
Run Name | Character variable that
identifies the problem solved. (Character, minimum 4; maximum 80 characters) |
Run Number | 1, 2, . . . |
- The Run Number is the same as the previous Radioss run.
- In the case of a control file, a "CHECK_DATA" file is automatically created by Radioss Engine with this option by using /CHKPT in Control File (C-File) Runname_run#.ctl. This file can be used to restart the computation as an input file for Radioss Engine instead of runname_run#.rad.
- It is also possible to put such an option inside a CHECK_DATA file you created.
