/INISHE/STRA_F or /INISH3/STRA_F
Block Format Keyword This describes the initial state for strain.
/INISHE/STRA_F/unit_ID or | |||||||||
/INISH3/STRA_F/unit_ID | |||||||||
shell_ID | nb_integr | npg | Thick |
1 | 2 | 12 | 23 | 31 | |||||
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
shell_ID | Element
identifier. (Integer) |
nb_integr | Integration point number
through the thickness. It corresponds to the property definition of this element. Must be equal to the number of integration points given in the shell property. (Integer) |
npg | Number of surface
quadrature points. Must be set according to the formulation which
is used in the shell property.
(Integer) |
Thick | Shell thickness. Will be
used instead of the thickness given into property or in the shell
definition. (Real) |
1 | Membrane strain in 1st
direction. (Real) |
2 | Membrane strain in 2nd
direction. (Real) |
12 | Membrane shear
strain. (Real) |
23 | Shear strain in direction
23. (Real) |
31 | Shear strain in direction
31. (Real) |
Bending strain in
direction 1. (Real) |
Bending strain in
direction 2. (Real) |
Bending strain in
direction 12. (Real) |
- For npg = 3 or 4, the optional continuation lines must be repeated npg times for each integration point.
- The initial state for shells may be defined by more than one block.
