/INIQUA/EPSP
Block Format Keyword Describes the initial state for a quad.
/INIQUA/EPSP/unit_ID | |||||||||
quad_ID | value |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
quad_ID | Element
identifier. (Integer) |
value | Data
value. (Real) |
- The initial state for quad may be defined by more than one block.
