/EULER/MAT
Block Format Keyword Describes the Euler material.
/EULER/MAT/mat_ID | |||||||||
Flrd |
mat_ID | Material identifier (Integer, maximum 10 digits) |
Flrd | Modification factor for fluxes at
boundaries.
(Real) |
Example (Air)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg m s
/MAT/HYDRO/4/1
AIR
# RHO_I RHO_0
1.22 0
# Knu Pmin
1.5E-5 0
/EOS/POLYNOMIAL/4/1
AIR
# C0 C1 C2 C3
0 0 0 0
# C4 C5 E0 Pmin RHO_0
0.4 0.4 253300 0 1.22
/EULER/MAT/4
# Modif. factor.
0
#enddata
/END
- If the boundary is not connected to a material specifying an Elementary Boundary
Condition (TYPE11), the Flrd is by default 0. The flow is reduced
otherwise by the Flrd factor value specified at the elementary boundary
level.
