/ALE/MAT
Block Format Keyword Describes the ALE material.
| /ALE/MAT/mat_ID | |||||||||
| Flrd | |||||||||
| mat_ID | Material
| Flrd | Modification
factor on boundary surfaces fluxes.
(Real) |
#RADIOSS STARTER
#- 1. MATERIALS:
/UNIT/1
unit for mat
g mm ms
/MAT/LAW37/1/1
air (unit g_mm_ms)
# Psh
0
# RHO_l0 C_l ALPHA_l NU_l NU_VOL_l
.001 2089 0 1.787e-3 0
# RHO_G0 GAMMA P0 NU_g NU_VOL_g
1.22E-6 1.4 .1 1.48e-2
/ALE/MAT/1
# Modif. factor.
0
/MAT/LAW37/2/1
water (unit g_mm_ms)
# Psh
0
.001 2089 1 1.787e-3 0
/ALE/MAT/2
# Modif. factor.
0
#enddata
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- If the boundary is
not connected to a material specifying an Elementary Boundary Condition
(TYPE11), the Flrd is by default 0. The flow is reduced
otherwise by the Flrd factor value specified at the
elementary boundary level.
