/BCS/CYCLIC
Block Format Keyword Defines a cyclic boundary condition on a structure in a fixed cylindrical coordinate system.
/BCS/CYCLIC/bcs_ID | |||||||||
bcs_cyclic_title | |||||||||
skew_ID | grnd_ID1 | grnd_ID2 |
Definition
bcs_ID | Boundary conditions block identifier. (Integer, maximum 10 digits) |
bcs_cyclic_title | Cyclic boundary conditions block title. (Character, maximum 100 characters) |
skew_ID | Skew identifier for the boundary conditions.
(Integer) |
grnd_ID1 | Node group of the first section. (Integer) |
grnd_ID2 | Node group of the second section. (Integer) |
- The node set grnd_ID1 and grnd_ID2 input are mandatory.
- Each node of the second section must have a corresponding node on the first section with the same cylindrical longitudinal and radial coordinates.
- The node group grnd_ID2 must have the same number of nodes of as the node group grnd_ID1.
- The directions X, Y, and Z
of the fixed local coordinate system skew_ID refer to
translations along the radial direction (r), azimuthal angular direction
), and longitudinal direction (Z).
