Manage Subsystem Representations
Subsystem representations allow a single subsystem to have multiple CAE representations that can be loaded into the session interchangeably.
For example, for front crash analysis you will want greater model fidelity in the front bumper, so you can load ‘Crash_5mm’ representation versus loading in ‘Crash_10mm’ representation when assembling a rear crash model where the increased level of detail is not required.
A folder-based Representation repository stores all CAE data that is required during the model build and assembly process.
Save the Representation
Once you have created a subsystem and populated it with content, you can save the representation locally or save a revision to the Subsystem Library.
Representations of subsystems are saved in solver deck format based on the current solver profile.
Add Representations From Files
Subsystem representations can be added from external sources such as solver decks.
Add Representations From the Subsystem Library
Subsystem representations can be added from external sources such as a subsystem library.
Add Representations to the Subsystem Library
Add representations to the library if they are in session.
Load Representations From Current HyperMesh Session
Subsystem representations can be loaded from the current HyperMesh session.
Load Representations From the Subsystem Library
Subsystem representations can be loaded from the subsystem library.
To exchange the current representation of the subsystem with a different one from the subsystem library, you can load the saved representation.
Unload Subsystem Representations
Unload subsystem representations from a session.
Delete Representations From the Current HyperMesh Session
Subsystem representations can be deleted from the current HyperMesh session.
When unloaded, FE entities of the representation do not exist in the current HyperMesh session. To completely delete the representation from a session, the representation itself can be deleted.
Delete Representations From the Part Library
Subsystem representations can be deleted from the Part library.
Browse Subsystem Library Content
Use the Library Viewer to review subsystem library content.
