poIScalarDefine SetMultipleLayers
Sets the multiple layers state.
poIScalarDefine_handle SetMultipleLayers mlayer
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the multiple layers state for the result definition. This state should be set if using the Top/Bottom layer in the result.
Note: The result definition can only be modified if it is not cached.
malyer
True to enable multiple layers, false otherwise.
To set the multiple layers state for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetIsMultipleLayers true
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
