poIScalarDefine GetValueFilter
Gets the value filter values.
poIScalarDefine_handle GetValueFilter
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, returns the value filter values for this result definition.
  • If the value filter is "None", an empty string is returned.
  • If the value filter is "<=" or ">=", "<value>0" is returned.
  • If the value filter is "Range", "<from> <to>" is returned.
To get the value filter values for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine GetValueFilter
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
