poIScalarDefine SetLayerFilter
Sets the layer filter of the result definition.
poIScalarDefine_handle SetLayerFilter id
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the layer filter ID for the result definition. Returns Success (0) or an error code.
Note: The result definition can only be modified if it is not cached.
id
The layer filter ID.
To set the layer filter ID of a scalar result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetLayerFilter 2
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
