poIScalarDefine SetDataComponent
Sets the data component of the result definition.
poIScalarDefine_handle SetDataComponent comp
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the data component for the result definition. Returns Success (0) or an error code.
Note: The result definition can only be modified if it not cached.
comp
The data component.
To set the data component of a scalar result definition to X:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetDataComponent X
hwi CloseStack
Returns an error code if there was an error setting the data component and sets error condition on the session handle. See session_handle GetError.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
