poIScalarDefine SetAverageFactorEnabled
Sets the nodal variation factor enabled state.
poIScalarDefine_handle SetAverageFactorEnabled enable
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the nodal variation factor enable state for this result definition.
Note: The result definition can only be modified if it is not cached.
enable
True to enable nodal variation, false to disable.
To set the average factor enabled state for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetAverageFactorEnabled true
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
