Open a Remote Session
Open a remote session and work on the interactive application.
Click the Sessions tab located in the upper left-hand of the page.
Note: By default, the session list is displayed in the Tile view. Click
to change the view to List view.
A sessions list is displayed. The session list displays the session screen preview and it is slightly blurred.
Figure 1. Session List -
Choose one of the following options:
- Double click a session name.
- Right click a session name and click Open.
- Right click a session name and click Open Session in New Tab.
A remote session of the interactive application is opened.
Figure 2. Opened Remote SessionsNote: By default, the timeout interval when a session is opened is set to unlimited. The default configured timeout value is set to 120 minutes (2 hours) for a remote session and it is displayed in session list timeout column while viewing the session. Time out will start when the session is closed, and the remaining time is displayed in session list timeout column.In the panel located on the left is a list of active sessions and the current session with the user name. Session options
are located in the top right-hand corner.
The session options displayed are:- view the remote session statistics panel. This option is displayed when the session is in inline view. By default, this option is disabled. Contact your Administrator to enable it.
- download the session runtime directory. This option is displayed when the session is in inline view. Only the session owner can download the session runtime directory.
- open the session in desktop
- change the resolution
- copy text to clipboard modal
- expand the session in full screen
- collapse the session from full screen. This option is displayed only when the session is expanded in full screen.
- screen capture of the session
- share the session
- terminate the session
- view and switch to other active session
Note: You canTip: Click the Sessions link on the left panel to view the list of active session.
