Open a Remote Session in a New Window
Open a remote session in a new window and work on the interactive application.
Click the Sessions tab located in the upper left-hand of the page.
A sessions list is displayed.
Figure 1. Session List -
Right click a session name and click Open Session in New
Tab
A remote session of the interactive application is opened in a new window.
Figure 2. Opened Remote SessionsNote: By default, the timeout interval when a session is opened is set to unlimited. The default configured timeout value is set to 120 minutes (2 hours) for a remote session and it is displayed in session list timeout column while viewing the session. Time out will start when the session is closed, and the remaining time is displayed in session list timeout column. -
Click
to view the session options.
Note: The session control displayed is a floating panel which can be moved.
Figure 3. Session ControlThe session control options are displayed.
Figure 4. Session Control Options- open the session in desktop
- change the resolution
- copy text to clipboard modal
- expand the session in full screen
- collapse the session from full screen. This option is displayed only when the session is expanded in full screen.
- screen capture of the session
- share the session
- terminate the session
- view and switch to other active session
