Extend the Session Timeout Interval
Extend the session expiry timeout interval.
By default, the timeout interval when a session is opened is set to unlimited. If the session is closed, then the timeout interval for the session is set to 120 minutes (2 hours).
  1. Click the Sessions tab located in the upper left-hand of the page.
    A sessions list is displayed with the timeout interval for each of the session.
    Figure 1. Session List
    The Extend Session dialog box is displayed if any of the session timeout interval is less than 5 minutes.
    Figure 2. Extend Session
  2. Click Extend Session.
    Note: If you extend the session, then the session timeout interval is set to another 120 minutes. If you open the session after extending the session, then the timeout interval is set to unlimited.
    Figure 3. Extended Session
