Revoke Access to a User Managed HPC Cluster
Managers can revoke access to an HPC cluster that has been added by a user with Monitor PBS Admin privileges.
Users with Monitor PBS Admin privileges can add an HPC cluster. A Manager can revoke this access to the cluster.
Once the access to the cluster is revoked, the user cannot re-add the cluster. If the user attempts to re-add the cluster, the message Cluster name already exists is displayed. The cluster still exists, the user just does not have access to it anymore.
  1. Click the Configure tab.
  2. Click Users from the Access Management menu located on the left-hand side of the web page.
  3. Click the name of the user.
    Select User
    Figure 1. Select User
  4. Click Edit.
  5. Click to revoke access to the cluster.
    Revoke Access to an HPC Cluster
    Figure 2. Revoke Access to an HPC Cluster
  6. Click Save.
    Access to the HPC cluster is revoked for the user and the following notification is displayed to the user if the user is currently logged into Control:
    Your view is updated to reflect the privilege changes in cluster: CLUSTER
    where CLUSTER is the name specified for the cluster.
