Delete an HPC Cluster
Delete an HPC cluster that you no longer want to monitor or administer.
Before deleting an HPC cluster see Requirements for Adding an HPC Cluster and HPC Cluster Accessibility.
Deleting a cluster means that you can no longer monitor jobs and nodes, or configure the Workload Manager associated with the HPC cluster.
  1. Choose one of the following options:
    • Click the Monitor tab to remove the ability to monitor and manage HPC cluster jobs and nodes.
    • Click the Configure tab to remove the ability to configure an HPC cluster.
  2. Click Manage Clusters.
    HPC clusters that have been previously added are listed on the left hand side of the dialog box.
    HPC Clusters
    Figure 1. HPC Clusters
  3. Click next to the name of the cluster that you want to delete.
  4. Click Remove.
    The cluster is removed.
    The following notification is displayed to any users that have been granted access to the HPC cluster based on their role, all Managers, and the user who added the cluster:
    Your view is updated to reflect the privilege changes in cluster: CLUSTER
    where CLUSTER is the name specified for the cluster.
  5. Click Close.
