Add a Comment to a Node
Add a comment to a node so that information pertaining to the node can be shared such as when a node is going to be taken offline.
Drill-down to get detailed information about the HPC cluster's nodes or nodes attached to a queue.
  1. Click in the Comment column corresponding to the node you would like to update.
    Add a comment
    Figure 1. Add a Comment
  2. Click inside the Comment box that appears.
    Add a comment
    Figure 2. Add a Comment
  3. Enter the text of the comment.
  4. Choose one of the following options:
    • Click to save the comment.
    • Click to cancel the change.
