Pressure Load
Apply positive pressure towards a face or negative pressure outwards from a face.
- In the Project Tree, open the Analysis Workbench.
- Click on the desired Analysis branch.
Next to Constraints, click the
(Add) button.
Choose
(Pressure) from the list of
loads.
The Pressure dialog opens. - In the modeling window, select one or more faces.
- Optional: Select the Add tangent faces check box.
- In the dialog, specify the Pressure value and units.
- Click OK.
