Distributed Mass
Apply distributed mass across select faces.
- In the Project Tree, open the Analysis Workbench.
- Click on the desired Analysis branch.
Next to Constraints, click the
(Add) button.
Choose
(Distributed mass) from the
list of loads.
- In the modeling window, select the desired faces.
- Optional: Select the Add tangent faces check box.
- Select either the Total Mass or Mass per area radio button.
- Specify a value for Total Mass or Mass per area.
- Click OK.
