Constraints
Restrict or limit movement in specific regions of the model.
- In the Project Tree, open the Analysis Workbench.
Click
to expand the desired analysis.
Next to Constraints, click the
(Add) button.
- Select the desired type of constraint from the context menu.
Set up the chosen constraint according to the following:
Constraint type Process Immovable and Slider Supports - In the dialog, select the button to apply to either Faces or Spots.
- In the modeling window, select the desired faces/spots.
Hinge Support In the modeling window, select the desired cylindrical faces. Spring Support - In the modeling window, select the desired faces.
- In the dialog, select either the Foundation factor or Support total stiffness radio button.
- For Foundation factor, select a Common foundation factor from the drop-down menu and specify values and units for X, Y, and Z.
- For Support total stiffness, specify values and units for X, Y, and Z.
Distributed Mass Available for Modal analysis. - In the modeling window, select the desired faces.
- Select either the Total Mass or Mass per area radio button.
- Specify a value for Total Mass or Mass per area.
Click OK.
The new constraint appears in the Project Tree.
