Gravity Load
Apply a uniformly distributed body load over the volumes of parts of an assembly.
Only one gravity load may be applied to the model.
  1. In the Project Tree, open the Analysis Workbench.
  2. Click on the desired Analysis branch.
  3. Next to Loads, click Add.
  4. Choose (Gravity load) from the list of loads.
    The Gravity load dialog opens.
  5. In the modeling window, select a part of the model.
  6. Specify load direction vectors for the X, Y, and Z axes.
  7. Specify the Amplification factor.
  8. Click OK.
    The load appears under the Load branch in the Project Tree. Vectors representing the load appear in the modeling window.
