Optimization will find the most effecitve design for each design space in a model in response to the applied loading
conditions on that model. You can run several different types of optimization including topology, topography,gauge,
lattice, and PolyNURBS shape optimization.
After running an optimization, if certain design targets or constraints were not met, a warning will appear at the
bottom of the Shape Explorer window.
The element density result type shows where material on the part is most dense and needs to be retained. This result
type is available for all topology optimization runs.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
