Compare the results of multiple optimization runs in a table using the Compare
Results button located at the bottom of the Shape Explorer.
Load the results in the Shape Explorer.
Click the Compare Results button located at the bottom
The table for comparing results appears at the bottom of the modeling
window.
Select the row to display the results for that run and load case.
- Double-click a cell in the table to show that result in the modeling
window.
- Click the chevron on a column header to filter results.
- Click a column header to sort the column.
- Right-click a column header to change what result types, run parameters,
or callouts are shown in the table.
- Click the top left corner of the table to copy the contents of all
cells. This can then be pasted into Excel.
