Run Options: Local vs. Remote
Choose whether to run jobs locally, in the cloud, or on a remote job server.
Click the Run group label to define how jobs are run.
Figure 1. Run Options Menu
These options are available for structural optimization and finite element analyses, but not motion, porosity, or thinning analyses.
Altair One
Run jobs in the cloud on Altair One. You will be asked to login first.
Local Sequential
Queue run requests on your local computer and run one after the other.
Local Parallel
Immediately execute all runs simultaneously on your local computer.
Manual Remote
Manually run a job on a remote server. Select this option if using a remote server that is not an Altair PBS server.
Custom Server
If you have added a remote server, the name of the server will appear in the menu. Select it to run jobs remotely on that server.
Add Server
Add and configure a remote job server.
