Add a Remote Job Server
Add and configure an Altair PBS server to run jobs remotely.
For more information about how to install and configure a PBS server, refer to the Inspire Remote Job Submission Guide, available on the Altair Help Center.
  1. Click the Run group label to display run options.
  2. Select Add Server.
  3. Enter the Name, Host, and Port.
  4. Click Save.
    A cloud icon appears next to the Run menu when the connection to the server has been established.
  5. Click the Run group label and verify that the server has been added.
  6. Set up and run an analysis or optimization using the Run Analysis or Run Optimization window.
Note:
If Inspire is integrated with Altair PBS Works, you can connect to an:
  • HPC Cluster running PBS Professional Workload Manager
  • HPC Cluster running LSF Workload Manager
