/VEL/TRA
Engine Keyword Given node numbers have the same velocity in a specified direction X, Y or Z for material translational DOF.
/VEL/TRA/Keyword3/skew_ID
N1 N2... NN
Data | Description | SI Unit Example |
Keyword3 | A combination of
X, v, and
Z: X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, ... |
skew_ID | Skew identifier
(optional). If omitted, the equation is written in the global skew system; otherwise it is applied in the given skew_ID. |
N1 N2 ... NN | List of node numbers having the same velocity. |
- Given node numbers have the same
velocity in a specified direction X, Y or Z for material translational DOF (Rigid
links):
(1)
