/BCS/ALE
Engine Keyword Given node numbers will be constrained in specified directions X, Y or Z for grid DOF: Ω = 0.
/BCS/ALE/Keyword3/skew_ID
N1, N2, . . ., NN
Data Description SI Unit Example
Keyword3 Any combination of X, Y, and Z:
X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, ...
skew_ID Skew identifier (optional).
If omitted, the boundary conditions are applied in the global skew system; otherwise they are applied in the given skew_ID.
N1, N2 ... NN List of nodes numbers to which the boundary conditions will be applied.
