Input File Format
A flexible body input file is a formatted file whose name is given is the /FXBODY in Radioss Starter.
It contains several blocks of data which must be input in the right order. Each line beginning with '#' is considered a comment line and is not taken into account.
Data block 1: General data
#FORMAT: (7I8)
#  Nbmod   Nbstat   Nbnod   Irot   Idamp   Iblo   Ifile
     45       15      18      1       0      1       0
Field Descripton SI Unit Example
Nbmod Total number of reduction modes
Nbstat Number of static modes
Note: Static modes are modes which are not orthogonal with respect to the stiffness. Their number gives the dimension of the full part of the local projected stiffness matrix. The number of so-called dynamic modes, given by (Nbmod - Nbstat) determines the size of the diagonal part of the local projected stiffness matrix.
Nbnod Number of nodes in the flexible body support.
Irot
0
Flexible body contains no elements with rotational DOF
1
Flexible body contains elements with rotational DOF
Idamp
0
No Rayleigh damping is used on the flexible body.
1
Iblo
0
Flexible body is free of blockage and its finite overall rotations and translations are computed.
1
Flexible has no rigid body modes.
Note: A flexible body is either fully free or fully blocked. A number of rigid body modes different from 0 or 6 in the local stiffness matrix is not permitted.
Ifile
0
All components of the modes and of the modal stress fields computed by Radioss Starter are stored in central memory.
1
Only the components of the attached to interface nodes of the flexible body (that is, nodes connected to the rest of the structure) are stored in central memory. The other components of the modes and all components of the modal stress fields computed by Radioss Starter, needed only for outputs, are stored on disk.
Data block 2: List of nodes
#FORMAT: (10I8)
#  Nodes
     21      22      23      24      25      26      27      28      29      30
     31      32      33      34      35      36      37      38
The number of nodes in the list must be equal to Nbnod given in Data block 1. The order of nodes in the list is the order in which the sets of components of the projection modes are given in Data blocks 5, 6, and 7.
Data block 3: Initial rotation matrix and local maximum frequency
#FORMAT: (1P5E16.9)
#         Mrot11          Mrot12          Mrot13          Mrot21          Mrot22
1.000000000E+00 0.000000000E+00 0.000000000E+00 0.000000000E+00 1.000000000E+00
#         Mrot23          Mrot31          Mrot32          Mrot33            Freq
0.000000000E+00 0.000000000E+00 0.000000000E+00 1.000000000E+00 2.049574631E+04
Field Descriptio SI Unit Example
Mrotij Component P|| of the initial rotation matrix from the local frame of the flexible body to the global frame.
Note: Matrix P defines the initial orientation of the flexible body.
Freq Maximum eigen frequency of the local reduced system composed of local reduced mass matrix and local reduced stiffness matrix.
Note: This frequency is used to compute the stability time step of the flexible body through the formula: Δ t s t a b = 1 π F r e q MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads hadaWgaaWcbaGaam4CaiaadshacaWGHbGaamOyaaqabaGccqGH9aqp daWcaaqaaiaaigdaaeaacqaHapaCcqGHflY1caWGgbGaamOCaiaadw gacaWGXbaaaaaa@4578@
Data block 4: Damping data (optional, present only if Idamp = 1)
#FORMAT: (1P2E16.9)
#         Alpha			    Beta
1.092357846E+01		4.652573369E-07
Description:
Field Description SI Unit Example
Alpha, Beta Rayleigh damping coefficients
Note: Local damping matrix is obtained from local reduced mass and stiffness matrices through the formula: C L = A l p h a M L + B e t a K L MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaBa aaleaacaWGmbaabeaakiabg2da9iaadgeacaWGSbGaamiCaiaadIga caWGHbGaeyyXICTaamytamaaBaaaleaacaWGmbaabeaakiabgUcaRi aadkeacaWGLbGaamiDaiaadggacqGHflY1caWGlbWaaSbaaSqaaiaa dYeaaeqaaaaa@49F7@
Data block 5: Projection modes - Modes representing the overall rigid body motion of the flexible body (optional, present only if Iblo = 0)
#FORMAT: (1P5E16.9)
#   1         X              Y                Z              XX              YY
#FORMAT: (1P1E16.9)
#            ZZ
0.000000000E+00-1.250000000E+01 0.000000000E+00 0.000000000E+00 0.000000000E+00
0.000000000E+00
0.000000000E+00 1.250000000E+01 0.000000000E+00 0.000000000E+00 0.000000000E+00
0.000000000E+00
12 modes Φ R i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuOPdy0aa0 baaSqaaiaadkfaaeaacaWGPbaaaaaa@3963@ with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaWcbaGaamyAaaaa@36E5@ =1…12 are input by blocks of Nbnod sets of six values (one set for each node of the support of the flexible body).
X, Y, Z Components of the mode on the translational DOF of the node.
XX, YY, ZZ Components of the mode on the rotational DOF of the node
0
If the node has no rotational DOF.
Data block 6: Projection modes - Modes accounting for the inertia associated with the rotational degrees of freedom (optional, present only if Iblo = 0 and Irot = 1)
Same format as Data block 5
3 modes Φ R 12 + i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuOPdy0aa0 baaSqaaiaadkfaaeaacaaIXaGaaGOmaiabgUcaRiaadMgaaaaaaa@3BBC@ with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaWcbaGaamyAaaaa@36E5@ =1…3 are input by blocks of Nbnod sets of six values.
Data block 7: Projection modes - Local reduction modes
Nbmod modes Φ L i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuOPdy0aa0 baaSqaaiaadYeaaeaacaWGPbaaaaaa@395D@ with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaWcbaGaamyAaaaa@36E5@ =1…Nbmod are input by blocks of Nbnod sets of six values. The Nbstat static modes are given first.
Data block 8: Local reduced diagonal mass matrix
#FORMAT: (1P5E16.9)
5.596016869E+03   8.234274572E+03  2.320889319E+04  1.215104250E+03  1.729160225E+02
3.000458618E+05   3.074228932E+02  1.458647403E+04  1.425398877E+02  4.251072139E+05
Nbmod values are entered, following the order in which the local modes are given.
Data block 9: Local reduced stiffness matrix - Full part
Same format as Data block 8
The shape of the matrix to input is: [Matsym Matrect]. The dimension of Matsym is Nbstat. The dimensions of Matrect are Nbstat * (Nbmod - Nbstat). The following order for input the terms is followed (for example: Nbmod = 6 and Nbstat = 3):(1)
[ 1 2 3 4 5 6 7 8 9 10 11 12 14 15 16 ]
It corresponds to a skyline storage of the Nbstat first lines of the local reduced stiffness matrix. The number of terms to input is 1 2 N b s t a t ( 2 N b m o d N b s t a t + 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaaca aIXaaabaGaaGOmaaaacaWGobGaamOyaiaadohacaWG0bGaamyyaiaa dshadaqadaqaaiaaikdacaWGobGaamOyaiaad2gacaWGVbGaamizai abgkHiTiaad6eacaWGIbGaam4CaiaadshacaWGHbGaamiDaiabgUca RiaaigdaaiaawIcacaGLPaaaaaa@4BEA@ . Again, the numbering of the columns of the matrix follows the order in which the local modes are given.
Data block 10: Local reduced stiffness matrix - Diagonal part
(Nbmod - Nbstat) values are entered, following the order in which the local dynamic modes are given.
Data block 11: Mass matrix projected on the modes defining the rigid body motion (optional, present only if Iblo = 0)
This is a full symmetric matrix entered using a skyline storage. Column numbering follows the order in which the modes defining the rigid motion are given. The dimension of the matrix is 12, if Irot = 0 or 15, if Irot = 1. Thus, the number of values to input is equal to 78, if Irot = 0 or 120, if Irot = 1.
Data block 12: Matrices for coupled mass projection (optional, present only if Iblo = 0)
Nine sub-blocks are given, one for each constant contribution M C k 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCytamaaBa aaleaacaWGdbGaam4Aaiaaigdaaeqaaaaa@396B@ . These are rectangular matrices. The number of lines is equal to 12, if Irot = 0 or 15, if Irot = 1. The number of columns is Nbmod. The terms of the matrices are entered line by line. Their number is equal to 12*Nbmod, if Irot = 0 or 15*Nbmod, if Irot = 1.
Data block 13: Matrices for coupled stiffness projection (optional, present only if Iblo = 0)
Nine sub-blocks are given, one for each constant contribution K C k 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4samaaBa aaleaacaWGdbGaam4Aaiaaigdaaeqaaaaa@3969@ . These are rectangular matrices. The number of lines is equal to 12, if Irot = 0 or 15, if Irot = 1. The number of columns is Nbmod. The terms of the matrices are entered line by line. Their number is equal to 12*Nbmod, if Irot = 0 or 15*Nbmod, if Irot = 1.
