/IMPL/LRIGROT
Engine Keyword Due to some linearization used in geometrical nonlinear analysis, small time step has to be chosen to avoid accumulated errors under large rotation. In this case, this option improves the accuracy using usual time step.
/IMPL/LRIGROT
