/IMPL/LINEAR
Engine Keyword Linear implicit solution will be computed.
/IMPL/LINEAR
- Required for linear statics, normal modes and linear buckling solution.
View new features for Radioss 2021.
Radioss format 2021 uses the 12x extension format.
Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword
Engine Keyword
Engine Keyword Euler buckling modes will be computed.
Engine Keyword Euler buckling modes will be computed based on actual pre-stress stat.
Engine Keyword Change the maximum number of BFGS quasi-Newton method for implicit nonlinear.
Engine Keyword Due to some linearization used in geometrical nonlinear analysis, small time step has to be chosen to avoid accumulated errors under large rotation. In this case, this option improves the accuracy using usual time step.
Engine Keyword Nonlinear implicit methods.
Engine Keyword Only small displacement effects will be considered with this option.
Engine Keyword Output global solve information at each solving iteration.
Engine Keyword Quasi-static implicit solution will be computed.
Engine Keyword Quasi-static implicit solution with a factor for inertia stiffness matrix.
Engine Keyword Rigid motion has been removed or minimized from quasi-static implicit solution.
Engine Keyword Selects linear solver.
Engine Keyword
Engine Keyword
Engine Keyword
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
This manual describes the interface between Altair Radioss and a user’s subroutines.
Engine Keyword
/IMPL/LINEAR
