/DRESP2
Optimization Keyword When a desired response is not directly available from OptiStruct, it may be calculated using /DRESP2. This response can be a functional combination of any set of responses resulting from the design analysis iteration. Responses defined in this manner can be used as design objectives or constraints.
The /DRESP2 card identifies the equation to use for the response relationship and the input values to evaluate the response function.
/DRESP2/resp_ID
title
FUNC EQID REGION
VARTYPE1 ID1 ID2 ID3 ID4 ID5 ID6 ID7 ID8 ID9
  ID10 ID11 ID12 etc
VARTYPE2 ID1 ID2 ID3 ID4 ID5 ID6 ID7 ID8 ID9
  ID10 ID11 ID12 etc
etc etc etc etc etc etc etc etc etc etc
resp_ID Design response identifier.
(Integer > 0)
title Title.
FUNC Function to be applied to the arguments.
= 1
SUM
= 2
AVG
= 3
SSQ
= 4
RSS
= 5
MAX
= 6
MIN
= 7
SUMABS
= 8
AVGABS
= 9
MAXABS
= 10
MINABS
(Integer > 0 or blank)
EQID /DEQATN identifier that defines the response relationship.
REGION Region identifier
Default = 0 (Integer ≥ 0)
VARTYPE# Indicates the type of variables to follow.
= 1
DESVAR
= 2
DNODE
= 3
DRESP1
= 4
DRESP2
= 5
DVPREL1
ID# When VARTYPE is DESVAR, DRESP1, DRESP2, or DVPREL1, this list of IDs reference entities of the defined VARTYPE.
/DRESP1/1
u_in
### RTYPE=5: Displacement
### PTYPE=1: Node
### ATTA=1 : Translational displacement in X-direction
### ATTI=103 : 103 is node group identifier is due to PTYPE = 1
#    RTYPE     PTYPE    REGION      ATTA      ATTB      ATTI
         5         1                   1                 103
/DRESP1/2
u_out
### PTYPE=1: Node
### ATTI=104 : 104 is node group identifier is due to PTYPE = 1
         5         1                   1                 104
/DRESP2/4
dresp2
### EQID=1: /DEQATN identifier is 1
### VARTYPE1=3: Indicates the type of variables is 3 (DRESP1)
### ID1=1: first Variable(x) is ID1=1 in DRESP1 (dx in node group 103)
### ID2=2: second Variable(y) is ID2=2 in DRESP1 (dx in node group 104)
#     FUNC      EQID    REGION
         1
# VARTYPE1       ID1       ID2       ID1       ID2       ID1       ID2       ID1       ID2       ID1
         3         1         2
/DEQATN/1
deqatn
# EQUATIONS
dm(x,y)=(x+y)/2.
  1. /DRESP2 entries must have unique identification numbers with respect to /DRESP1 entries.
  2. Any number of VARTYPE# continuation lines can be defined. The order in which the VARTYPE# continuation lines are listed on the /DRESP2 card is not specified. The same VARTYPE# can be repeated any number of times, in any position, on the card. However, the order in which the VARTYPE# continuation lines are listed will affect the solution as the values are passed to the equation (or function) in the listed sequence.
  3. /DRESP2 cannot reference itself directly or recursively, but multiple levels of referencing are allowed.
  4. If VARTYPE is DNODE, a list of NODE could be defined, where every second value is a NODE identifier. For example:
    "DNODE, 11, 2" indicates the Y coordinate of NODE Number 11.
    Sequence is repeated for VARTYPE = DNODE. For example:
    "DNODE, 11, 2, 12, 1" indicates the Y coordinate of NODE Number 11 and X coordinate of NODE Number 12.
  5. The following functions can be used instead of an EQID. If FUNC is used, the /DEQATN entry is no longer needed. The functions are applied to all arguments on the /DRESP2 regardless of their type.
    Function Description Formula
    SUM Sum of arguments SUM( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m y i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaci4uaiaacw facaGGnbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaabCaeaacaWG5bWaaSbaaSqaaiaadMgaaeqaaaqaaiaadMgacq GH9aqpcaaIXaaabaGaamyBaaqdcqGHris5aaaa@508C@
    AVG Average of arguments AVG( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m y i m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciyqaiaacA facaGGhbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaSaaaeaadaaeWbqaaiaadMhadaWgaaWcbaGaamyAaaqabaaaba GaamyAaiabg2da9iaaigdaaeaacaWGTbaaniabggHiLdaakeaacaWG Tbaaaaaa@5181@
    SSQ Sum of square of arguments SSQ( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m y i 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaci4uaiaaco facaGGrbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaabCaeaacaWG5bWaa0baaSqaaiaadMgaaeaacaaIYaaaaaqaai aadMgacqGH9aqpcaaIXaaabaGaamyBaaqdcqGHris5aaaa@514B@
    RSS Square root of sum of squares of arguments RSS( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m y i 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOuaiaaco facaGGtbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaOaaaeaadaaeWbqaaiaadMhadaqhaaWcbaGaamyAaaqaaiaaik daaaaabaGaamyAaiabg2da9iaaigdaaeaacaWGTbaaniabggHiLdaa leqaaaaa@5167@
    MAX Maximum of arguments
    MIN Minimum of arguments
    SUMABS Sum of absolute value of arguments SUM( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m | y i | MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaci4uaiaacw facaGGnbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaabCaeaadaabdaqaaiaadMhadaWgaaWcbaGaamyAaaqabaaaki aawEa7caGLiWoaaSqaaiaadMgacqGH9aqpcaaIXaaabaGaamyBaaqd cqGHris5aaaa@53C3@
    AVGABS Average of absolute value of arguments AVG( y 1 , y 2 ⋅⋅⋅ y m )= ∑ i=1 m | y i | m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciyqaiaacA facaGGhbWaaeWaaeaacaWG5bWaaSbaaSqaaiaaigdaaeqaaOGaaiil aiaadMhadaWgaaWcbaGaaGOmaaqabaGccqGHflY1cqGHflY1cqGHfl Y1caWG5bWaaSbaaSqaaiaad2gaaeqaaaGccaGLOaGaayzkaaGaeyyp a0ZaaSaaaeaadaaeWbqaamaaemaabaGaamyEamaaBaaaleaacaWGPb aabeaaaOGaay5bSlaawIa7aaWcbaGaamyAaiabg2da9iaaigdaaeaa caWGTbaaniabggHiLdaakeaacaWGTbaaaaaa@54B8@
    MAXABS Maximum of absolute arguments
    MINABS Minimum of absolute value of arguments
