/DELINT
Engine Keyword If a secondary node is only connected to 2D solid elements that are all deleted, the node is deactivated from the interface.
/DELINT/Keyword2
Data | Description | SI Unit Example |
Keyword2 | Activation flag.
- In 3D, this option has been replaced by Idel interface flag in Starter Input file.
