/DEL
Engine Keyword Delete element numbers N1, N2, . . ., NN.
/DEL/Eltyp
N1, N2 . . ., NN
Field Content SI Unit Example
Eltyp Element type:
BRICK
Brick elements
QUAD
Quad elements
SHELL
Shell elements
SH_3N
Triangular shell elements
SPHCEL
SPH elements
TRUSS
Truss elements
BEAM
Beam elements
SPRING
Spring elements
N1, N2, . . ., NN List of element numbers
  1. For element numbers, it is possible to enter several lines.
  2. Elements with void material cannot be deleted.
