/DEL/Eltyp/1
Engine Keyword Delete element numbers N1first to N1last, . . ., NIfirst to NIlast.
/DEL/Eltyp/1
N1first N1last ... NIfirst NIlast
Field Content SI Unit Example
Eltyp Element type:
BRICK
Brick elements
QUAD
Quad elements
SHELL
Shell elements
SH_3N
Triangular shell elements
SPHCEL
SPH elements
TRUSS
Truss elements
BEAM
Beam elements
SPRING
Spring elements
N1first ... N1last First and last element number of a range to delete.
  1. For element numbers, it is possible to enter several lines.
  2. Elements with void material cannot be deleted.
