udfSetUgdData()
Set the value of a user global data.
udfSetUgdData( udfHd, ugd, ugdData ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- ugd (string)
- Name of the user global data variable.
- ugdData (real)
- Value of the user global data.
Return Value
None
udfSetUgdData( udfHd, "nCols", 2. ) ;Errors
- This routine expects a valid udfHd.
- ugd must exist.
- May only be called from a multiplier function or a mesh motion user-defined function.
