udfGetGlobalHistsCurr3()
Get the current global history variables.
vec = udfGetGlobalHistsCurr3( udfHd, nSize, id1, id2, id3 ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- nSize (integer)
- Size of vector.
- id1 (integer)
- index 1.
- id2 (integer)
- index 2.
- id3 (integer)
- index 3.
Return Value
- vec (real)
- Pointer to the global vector
Real* vec ;
vec = udfGetGlobalHistsCurr3( udfHd, nSize, id1, id2, id3 )Errors
This routine expects a valid udfHd.
