udfHasTurb()
Does this problem contain a turbulence equation?
turbFlag = udfHasTurb( udfHd ) ;
AcuSolve User-Defined Function Global
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
turbFlag (integer)
Flag indicating whether or not this problem has turbulence equation(s).
The return value is a flag indicating whether or not this problem has turbulence equations:
0
No
1
Yes
This routine determines if this problem contains a turbulence equation. For example,
Integer turbFlag ;
if ( turbFlag == 1 ) {
   /* Logic if turbulence equations exist */
This routine expects a valid udfHd.
