Add an Analysis
Use the Analysis tool to add an analysis to the model.
  1. From the Project Browser right-click on the Model label (or any system of your choice) and selecting Add > analysis.
    The Add Analysis dialog is displayed.
  2. Select the type of analysis to add.
  3. If you selected Uses data and definition file, complete the steps below:
    1. Select how to add the analysis.
    2. Depending on the method selected, use the fields to create a new file, or browse to select an existing file.
  4. Assign a variable name and label to the analysis.
  5. Specify a definition name for the system.
  6. Click OK to close the window or Apply to continue creating entities.
    The analysis is added to the model.
