Add Representations from the Part Library
  1. In the Part Browser, right-click on a part/part assembly and select Representations > Add > from Library from the context menu.
  2. In the Add Representations from Library dialog, select representations to add.
  3. Optional: To simultaneously add and load representations, select representations to load from the Load Added Representations list.
  4. Click OK.
