Create subsystem connectors using FE Absorb.
If you have an existing mesh but no connector, you can create connectors and
attachments by selecting the mesh manually and defining the FE type, or
automatically where HyperMesh finds any mesh that
matches the FE type.
In the Connector Browser, right-click and select .
The Create Subsystem Connectors dialog opens.
In the Selection field, choose either Manual or
Automatic from the drop-down list.
In the Location Entity field, use the Elements selector
to select the appropriate elements.
In the FE Type field, select the appropriate item from the drop-down
list.
For Tolerance, type an appropriate value.
Click Create.
